Введение
This guide explains to how safely locate and remove the battery from your Lenovo Yoga 2 13". It provides a list of the tools required, as well as the easiest way to remove the battery without causing damage.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
Disconnect the battery from the laptop by pulling the power connector towards the battery.
Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
12 участников успешно повторили данное руководство.
