Lenovo Yoga 2 13" Screen Replacement
Выберете то, что вам нужно
  1. Lenovo Yoga 2 13" Screen Replacement, Screen: шаг 1, изображение 1 из 2 Lenovo Yoga 2 13" Screen Replacement, Screen: шаг 1, изображение 2 из 2
    • Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
    • Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
  2. Lenovo Yoga 2 13" Screen Replacement: шаг 2, изображение 1 из 1
    • Using the Jimmy, remove the long centerpiece covering between the hinges.
  3. Lenovo Yoga 2 13" Screen Replacement: шаг 3, изображение 1 из 1
    • Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
  4. Lenovo Yoga 2 13" Screen Replacement: шаг 4, изображение 1 из 1
    • Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
    • Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
  5. Lenovo Yoga 2 13" Screen Replacement: шаг 5, изображение 1 из 2 Lenovo Yoga 2 13" Screen Replacement: шаг 5, изображение 2 из 2
    • Completely separate the screen from the laptop.
    • During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
Заключение
11 участников успешно повторили данное руководство.
Nichelle
Участник с: 03/11/15
1 550 Репутация
Автор 5 руководств
Команда
Marist, Team 1-2, Laflen Spring 2015 Участник Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 членов
Автор 7 руководств
3 Комментариев
Hi Nichelle,
thanks for your guide. Step 1 and 2 - no problem. But how actually did you do step 3? I can't detach the screen, I can just lift it a few millimeters at the corners or at the side, totally hard..
edit: Ok got it: slide the touch-lcd up a bit :)
Simon - Ответить
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
Emmanuel Duarte - Ответить
I used laptopscreen.com.
ken - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 21
За всё время: 15,973
