Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
Using the Jimmy, remove the long centerpiece covering between the hinges.
Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
11 участников успешно повторили данное руководство.
3 Комментариев
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
