Введение
Use this guide to replace the motherboard in your Lenovo Yoga 3 11.
Выберете то, что вам нужно
Remove the eleven 6 mm T5 Torx screws securing the lower case.
Gently lift the lower case up and away from the device.
Use a pair of tweezers to gently disconnect the speaker cable.
Remove the wires from underneath the battery tabs using the tweezers.
Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
Use a plastic opening tool to gently pry up the screen cable from the motherboard.
Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
Remove the ribbon cable from the device.
Remove the two 2 mm Phillips #00 screws securing the wireless card (top) and the SSD (bottom).
Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
Gently lift the wireless card and SSD up and out of the device.
Remove the three black 2 mm Phillips #00 screws.
Remove the single silver 4 mm Phillips #00 screw.
3 участников успешно повторили данное руководство.
Один комментарий
Not as difficult as I thought. I was surprised that there were no empty RAM locations. Usually on a Notebookk lliek this, there is one RAM location soldered to MB, and one empty slot for upgrade. I worked on an identical Yoga 3 pro that ran 16GB. But aht meant it was soldered at factory to one 16GB RAM setup.
