Введение
Is nothing showing on your laptop's screen? Are you looking for a solution? Then you have come to the right place! This guide will help you remove and replace your laptop's screen.
Выберете то, что вам нужно
Use a plastic opening tool or the pointed end of a spudger to pry up the 2 rubber inserts in the bottom left and right corners of the screen.
Work the plastic opening tool in between bezel and the upper case.
Once the plastic opening tool is wedged in between the two, work the plastic opening tool around the perimeter of the screen, separating the bezel from the display.
Use the tweezers to pull the tape upwards. The tape will pull the wires up with it, separating the connection.
Use the tweezers to follow the wires and move them out from under the plastic hooks.
Use the tweezers to pull the tape upwards in order to free the wires underneath it.
Use the tweezers to pull up the camera by simply pulling upwards on the tape that is over it.
Use the tweezers to follow the wires and to pull them out from under the plastic black hooks. Also pull up any tape that is over the wires.
Use the plastic opening tool to work the black component up and out of its original spot, then pull out the following connected wires.
Use the tweezers to unplug the black connection near the hinge of the laptop, taking the yellow tape off with it.
Еще один человек закончил это руководство.
