Введение
The tools needed to replace the USB Port in the Lenovo Yoga 3 Pro are T5 Torx screwdriver, PH0, and a spudger.
Выберете то, что вам нужно
Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
Gently lift the backing off the laptop.
Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
Take out the 3, 3mm screws from the left hinge using the PH0 head.
Remove the 1, 4mm screw that connects the hinge to the USB port.
Carefully lift the hinge enough to separate it from the USB port.
The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
2 участников успешно повторили данное руководство.
2 Комментариев
Anyone know where I can buy this part? Cannot find it anywhere…
