Введение
This guide will outline the proper procedure for removal of the display assembly. Exercise caution while removing and handling the assembly and its components, as they can easily scratch. Remember to turn the laptop off prior to starting.
Выберете то, что вам нужно
Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
Slide the plastic opening tool between the base cover and the frame to pry open the computer.
Slowly go around the entire perimeter of the computer until all edges are loose.
Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
Hi
I have a Lenovo Yoga 3 pro - 1370
I take off the SSD without remove the battery. Is this a problem?
TKS
Stanley
Carefully lift and remove the battery.
If you have the right tools, this is really straightforward to do. Took me about 10 minutes. The instructions are very accurate.
Regarding the battery connector, the male plug is attached to the battery wiring (you will know what I mean when you look at it) and the female socket is attached to the logic board. There are small ridges on either side of the plug that can be grasped with fingernails to gently tease the plug out of the socket.
Remove the speaker and set it on the side.
Use the plastic opening tool to remove the cables.
Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
Pull the second USB hub off.
I need to replace this part. Why don't you sell it here? Love the instructions, but need the spare part.
Remove the four 2mm screws using the Philips 00 screwdriver.
Remove the 2.5mm screw using the Philips 00 screwdriver.
Use the plastic opening tool to lift the screen cover from the screen assembly.
Unclip the display assembly by sliding the display down, towards the lower edge of the upper case component. The clips will disengage and you will be able to lift the assembly out easily.
10 участников успешно повторили данное руководство.
2 Комментариев
Thank you. Very useful.
Great guide, but I think you missed the part of removing the fan
