Введение
This guide will show you how to remove the motherboard from the Lenovo Yoga 3 Pro. As an extra precaution, the battery should be removed first before proceeding with the rest of the device.
Выберете то, что вам нужно
Flip the laptop so that the back panel is facing up.
Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
Using the plastic opening tool, gently pry the grey wire off the wifi card.
Pry the black wire off the wifi card.
Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
Lift the daughter board, unrouting the wireless cables from their plastic holders, and place it to the side.
Detach the five flat flex cables attached to the motherboard as follows:
1. Flip the cable holder up with a finger nail
2. Pull on the tab to remove the cable.
Remove the four #0 2.3mm Phillips screws holding down the motherboard.
Remove the two #0 2.9mm Phillips screws holding down the fan.
Flip the cable lock holding down the monitor connector.
Remove the monitor connector by tugging on the tab.
5 участников успешно повторили данное руководство.
2 Комментариев
Hi. Do you have any idea where I could by a replacement motherboard and how much that would cost? Please answer to martin.loffler@gmail.com. Thank you so much. Best, Martin
