Введение
Is your laptop having wireless connectivity issues? Your wireless card may be faulty. This guide walks you through the process of removing the wireless card so you can replace it and get back to surfing the web.
Выберете то, что вам нужно
Flip your device so that the bottom panel is facing up.
Remove the eleven 5mm Torx T5 screws from the back panel.
Use a spudger to unclip clips on the front and near the USB ports on each side
Lift the back panel off
Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
Place the laptop with the LCD facing down so that the hinges face opposite you.
Disconnect both ends of the two blue ZIF (zero insertion force) connectors in the upper left corner and by gently flipping the black tabs on the connector and pulling up and away from both ends of the connectors.
Unplug the black and white wireless LAN cables in the upper left corner by gently pulling upwards.
Remove the one 2mm Phillips #1 screw.
Remove the card by pulling to the left and up.
Еще один человек закончил это руководство.
