Lenovo Yoga 700-11ISK Wireless Card Replacement
Выберете то, что вам нужно
  1. Lenovo Yoga 700-11ISK Wireless Card Replacement, Back Panel: шаг 1, изображение 1 из 2 Lenovo Yoga 700-11ISK Wireless Card Replacement, Back Panel: шаг 1, изображение 2 из 2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Wireless Card Replacement: шаг 2, изображение 1 из 1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Wireless Card Replacement, Battery: шаг 3, изображение 1 из 1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Wireless Card Replacement: шаг 4, изображение 1 из 1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Wireless Card Replacement, Wireless Card: шаг 5, изображение 1 из 3 Lenovo Yoga 700-11ISK Wireless Card Replacement, Wireless Card: шаг 5, изображение 2 из 3 Lenovo Yoga 700-11ISK Wireless Card Replacement, Wireless Card: шаг 5, изображение 3 из 3
    • Place the laptop with the LCD facing down so that the hinges face opposite you.
    • Disconnect both ends of the two blue ZIF (zero insertion force) connectors in the upper left corner and by gently flipping the black tabs on the connector and pulling up and away from both ends of the connectors.
    • Do not pull on the blue tab of the cable without lifting up the black tabs on the connectors. The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  6. Lenovo Yoga 700-11ISK Wireless Card Replacement: шаг 6, изображение 1 из 1
    • Unplug the black and white wireless LAN cables in the upper left corner by gently pulling upwards.
    • To reinstall a wireless LAN card, note that the black cable goes to the MAIN jack, and the white to the AUX jack.
  7. Lenovo Yoga 700-11ISK Wireless Card Replacement: шаг 7, изображение 1 из 2 Lenovo Yoga 700-11ISK Wireless Card Replacement: шаг 7, изображение 2 из 2
    • Remove the one 2mm Phillips #1 screw.
    • Remove the card by pulling to the left and up.
Заключение
Еще один человек закончил это руководство.
Gabrielle Bullen
Участник с: 10/06/16
372 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 15-6, Livingston Fall 2016 Участник Cal Poly, Team 15-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G6
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 1,222
