Введение
The back panel protects the inside of your device from damage. If your back panel is broken, use this guide to replace it. Only remove this if your trying to replace something on the inside or the back panel itself.
  1. Make sure back panel is facing up. Remove eleven 5mm screws with the T5 Torx Screwdriver.
    • Make sure back panel is facing up.
    • Remove eleven 5mm screws with the T5 Torx Screwdriver.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  3. Lift back panel carefully.
    • Lift back panel carefully.
    • You can now replace back cover, making sure to match screw holes and placement of the original.
Заключение
2 участников успешно повторили данное руководство.
Teairra Woods
Участник с: 11.04.2017
249 Репутация
Автор 2 руководств
Команда
University of Memphis, Team S1-G4, Kim Spring 2017 Member of University of Memphis, Team S1-G4, Kim Spring 2017
UM-KIM-S17S1G4
4 членов
Автор 2 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
За всё время: 720
