Введение
If your device isn’t properly registering clicks or cursor movements, the trackpad may be faulty. Follow these instructions to remove and replace the trackpad in your Lenovo Yoga 710-11ISK.
Выберете то, что вам нужно
Flip the device having the bottom panel facing you.
Remove the eleven 5mm Torx T5 screws from the back panel.
Remove the two 3mm Phillips #1 screws that are holding the battery to the device.
Hold the bundled cable connector on each side and carefully pull the connector to release it from the motherboard.
Remove the battery carefully from the device by lifting up the edge nearest you and then gently pull toward you to disconnect the power wires.
Using a Phillips #00 screwdriver, remove the three 3mm screws located at the top of the trackpad.
