Введение
This simple guide will show you how to unscrew and remove all cables from the motherboard of a Lenovo Yoga 710-14KB besides the display cable, which will need to be unsoldered.
Выберете то, что вам нужно
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
3 участников успешно повторили данное руководство.
