Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide shows how to properly remove the bottom case.
  1. Start by flipping the device over so that you see the screws. Remove 7 Torx T5 short screws. Remove 3 Torx T5 long screws.
    • Start by flipping the device over so that you see the screws.
    • Remove 7 Torx T5 short screws.
    • Remove 3 Torx T5 long screws.
  2. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
    • starting from the USB port use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the orders the arrows show.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lift the case from the bottom side. NOT the side with the hinges. When you feel resistance, do NOT keep lifting or you will damage the housing. Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
Заключение
4 участников успешно повторили данное руководство.
Aiden Baker
Участник с: 19.09.2015
13 876 Репутация
Автор 20 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 26
За последние 30 дней: 126
За всё время: 4,559
