Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will show how to replace the SSD.
  1. Start by flipping the device over so that you see the screws. Remove 7 Torx T5 short screws. Remove 3 Torx T5 long screws.
    • Start by flipping the device over so that you see the screws.
    • Remove 7 Torx T5 short screws.
    • Remove 3 Torx T5 long screws.
    • starting from the USB port use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the orders the arrows show.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  2. Lift the case from the bottom side. NOT the side with the hinges. When you feel resistance, do NOT keep lifting or you will damage the housing. Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove 4 J1 Philips screws.
    • Remove 1 J1 philips screw
    • Do not mix these screws up, as if you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • slightly lift the battery using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  4. Pull the battery towards you until the wire is accessible. gently tug and wiggle on the wire until it pops out. Remove the battery.
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
  5. This is the SSD remove the warranty sticker Removing the warranty sticker and placing it back after may still void your warranty.
    • This is the SSD
    • remove the warranty sticker
    • Removing the warranty sticker and placing it back after may still void your warranty.
    • Remove 1 J1 Screw holding the SSD Remove the screw holding the SSD.
    • Update! I removed the size due to a lot of people having issue with stripping the screw when using the suggested size. I will look at this again when I have time. sorry for the inconvenience this caused many of you. use what you think works best here.
  6. Slightly lift the rear of the SSD If you lift too far you could damage the motherboard connector or the SSD.
    • Slightly lift the rear of the SSD
    • If you lift too far you could damage the motherboard connector or the SSD.
    • Gently pull it out.
Заключение
17 участников успешно повторили данное руководство.
Aiden Baker
Участник с: 19.09.2015
13 354 Репутация
Автор 20 руководств
Комментариев: 10
Your lucky to have a M.2 ssd. Also take those labels off if your going to have it serviced they may think you have opened it.
Padraic Hoselton - Ответить
Thanks @paperboypaddy. those labels were always on it. I do need it serviced now though.
Aiden Baker -
I was able to take off the battery. But I stripped the screw for the ssd. It would not come out. I used what I thought was the correct screwdriver. Can any help me?
Thank you,
Alberto
Email: defdasm@yahoo.com
Alberto Loya - Ответить
Stripping the screw usually only happens if a] you’re using a screwdriver that’s the wrong size, or b] you aren’t applying sufficient pressure. You may be able to remove the screw by using some fine/needlenose pliers, but I’d urge caution in doing so, and you might want to take this somewhere to have it done professionally if you’re at all uncomfortable doing so safely. Once you’ve loosened it, remove it by hand if possible.
Also, I’d recommend you replace the screw while you have the case apart. It is most likely a metric, m2 (as in, m1, m2, m3, etc. unrelated to the M.2 SSD form factor) x 3mm long, though the length may vary by about 0.5mm. You can sometimes find these at local hardware stores like Ace or a locally-owned non-Ace store. Larger hardware stores like Home Depot or Lowes (in the US) are less likely to carry metric screws that small.
OwThatHertz -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 41
За последние 30 дней: 186
За всё время: 13,020
