Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$5.49-
Remove seven Torx T5 short screws.
Remove three Torx T5 long screws.
Инструмент, используемый на этом этапе:iFixit Opening Tool$1.99-
Starting from the USB port, use your opening tool to gently pry up the case.
Pry along the laptop in the order shown by the arrows.
Lift the case from the bottom side. NOT the side with the hinges.
Once you feel resistance, gently pull the case towards you. (away from the hinges.)
Remove the case.
Инструмент, используемый на этом этапе:JIS Driver Set$19.99-
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
Pull the battery towards you until the wire is accessible.
gently tug and wiggle on the wire until it pops out.
Remove the battery.
Remove the left speaker.
Remove the Adhesive.
Use this pull tab to remove it.
Remove the right speaker,
5 участников успешно повторили данное руководство.
