Введение
If the SSD in your Lenovo Yoga 720-12IKB is not showing up on boot or it gets corrupted. You may need to replace the SSD.
The SSD in the Lenovo Yoga 720-12IKB is very important to the system as everything lives there. Your files, operating system, and other media are all stored on the SSD of your computer. This is an important part in most laptops so without it you will not be able to use your laptop.
Use caution when taking out the SSD as you could damage other components in the system. Be sure to make a backup of everything on a separate drive to not lose any important files or documents.
Выберете то, что вам нужно
Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
Pull down on the cover to remove it and you will see the battery after removing the cover.
Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
You will find the SSD above the Battery. Remove the 3.0 mm Phillips #00 screw.
After undoing the screw lift the SSD up and pull to the right to remove it from the system.
