Введение
Use this guide to replace the touchpad on a Lenovo Yoga 730 13-IKB (model numbers starting with “81CT”). The touchpad translates finger movement and presses into inputs on the computer.
Scratches, cracks, and liquid spills can all cause a touchpad to malfunction or stop working entirely. Review these potential software fixes for a problematic touchpad before physically replacing the touchpad assembly.
There are no special skills required for this guide. While not necessary, a hairdryer or heat gun can help remove adhesive tape within the device. Keep any debris or liquids away from the computer while replacing the touchpad because the internal components of the laptop will be exposed.
Выберете то, что вам нужно
Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
Disconnect the battery cable by gently pulling it straight out of the connector.
Remove the battery by pulling up near the white label and lifting diagonally away from the laptop.
Use a Phillips #00 screwdriver to remove the six 2.5mm screws holding down the touch pad.
Peel the yellow tape off of the touchpad connector.
Gently push the gray tab up on the connector using a spudger. Pull out the cable.
Hold the top of the touchpad and gently pull up.
Lift the touchpad diagonally away from the laptop.
