Введение
Use this guide to replace the touchscreen display on a Lenovo Yoga 730 13-IKB (model numbers starting with “81CT”). The touchscreen display functions as a regular display and also recognizes direct, physical user input.
Many screen-related problems can be remedied with software fixes. Review the Lenovo Yoga 730-13IKB troubleshooting guide if you are experiencing display issues before replacing the touchscreen assembly.
Replacing the touchscreen is an advanced process and is recommended for confident users. Keep any debris or liquids away from the computer while replacing the motherboard because the internal components of the laptop are exposed.
Выберете то, что вам нужно
Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
Disconnect the battery cable by gently pulling it straight out of the connector.
Remove the battery by pulling up near the white label and lifting diagonally away from the laptop.
Use a Phillips #00 screwdriver to remove the eight 2.5mm screws securing the heat sink assembly.
Release the fan connector by gently pushing the gray locking tab up using a plastic spudger. Do this for both of the fans.
Pull each fan cable straight out of the connector.
Remove the heat sink assembly by holding the middle plate and rotating the assembly down towards the back of the motherboard.
Pull the heat sink diagonally away from the laptop.
Use a Phillips #00 screwdriver to remove the six 2.5mm screws holding down the touch pad.
Peel the yellow tape off of the touchpad connector.
Gently push the gray tab up on the connector using a spudger. Pull out the cable.
Hold the top of the touchpad and gently pull up.
Lift the touchpad diagonally away from the laptop.
Use a Phillips #00 screwdriver to remove the five 3.5mm screws securing the motherboard.
Use a Phillips #000 driver to remove the four 3mm screws holding down the connector bracket.
Use a spudger to remove the bluetooth cable by flipping up the gray connector tab. Pull out the cable.
Use a spudger to remove the fingerprint sensor cable by flipping up the gray connector tab. Pull out the cable.
Use a spudger to remove the keyboard cable by flipping up the gray connector tab. Pull out the cable.
Use a Phillips #00 screwdriver to remove the 2.5mm screw securing the LAN card.
Remove the motherboard by holding it by the bottom and pulling diagonally away from the laptop.
Use a Phillips #00 screwdriver to remove the four 4mm display hinge screws.
Rotate the screen hinge next to the LAN card away from the laptop frame.
Pull the black LAN card wire through the hinge and unhook it from the holding tabs.
Rotate the screen hinge above the display connector away from the laptop frame.
Pull the black display cable bundle through the hinge.
