Lenovo Yoga 910-13IKB Battery Replacement
Выберете то, что вам нужно
  1. Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: шаг 1, изображение 1 из 2 Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: шаг 1, изображение 2 из 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Battery Replacement, Battery: шаг 2, изображение 1 из 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Battery Replacement: шаг 3, изображение 1 из 3 Lenovo Yoga 910-13IKB Battery Replacement: шаг 3, изображение 2 из 3 Lenovo Yoga 910-13IKB Battery Replacement: шаг 3, изображение 3 из 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
9 участников успешно повторили данное руководство.
Pablo Gonzalez
Участник с: 01/23/20
538 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S1-G5, White Winter 2020 Участник Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 членов
Автор 14 руководств
4 Комментариев
Step 3-6 are redundant to simply change the battery, correct?
oslodave - Ответить
You're right! I fixed the guide to reflect this.
Arthur Shi -
Maybe I haven't seen many battery connectors, but this is one of the most annoying to reinsert.
Noah - Ответить
Easy battery replacement on Yoga 910. The repair kit contains a variety of small repair tools and is very nice for the price. Found some small metallic discs when disassembled; they were spacers for the screws in the back casing and superglued them back to the casing before reassembly.
InfamousB - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 40
За последние 30 дней: 193
За всё время: 10,208
