Введение
This guide will show you how to replace the Lenovo Yoga 920-13IKB's battery.
Выберете то, что вам нужно
Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
Slide the iFixit Opening Tool under the back cover to lift it up.
Pull up on the cover with your hand to release the tab holding the center of the cover in place.
Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
29 участников успешно повторили данное руководство.
13 Комментариев
What is the correct replacement battery for this device?
Nice writeup!
Simple, a real simple straight forward process with the right tools of course. Thanks
Simple and easy. Great guide to! Thanks so much
