Введение
The guide shows how to replace the screen on the Lenovo Yoga 920-13IKB.
Выберете то, что вам нужно
Pry the metal cover up from the bottom of the screen with the iFixit Opening Tool to reveal the corners of the white adhesive strip.
Pull the metal cover off the device until it's completely free.
Remove the eight 3mm Phillips #000 screws that were below the metal cover to loosen the screen.
Pull out the white adhesives using the iFixit Tweezers.
Roll the tape around the iFixit Tweezers to remove successfully.
Lift the screen with your hands and place the the screen face down, keeping the device in the same location.
Flip up the black tab on the connector at the top of the screen with the iFixit Opening Tool.
Flip up the black tab on the smallest connector at the bottom of the screen with the iFixit Opening Tool.
Flip up the thick black cable at the bottom of the screen with your thumb.
Use the iFixit Opening Tool to lift up the brass tab to free up the cable.
Remove the ribbon cable from the connector to detach the screen from the device.
Еще один человек закончил это руководство.
5 Комментариев
Does this also appy to the Yoga 910-13IBK?
Alyssa, I am about to tackle this job to replace a cracked screen - I greatly appreciate your guide. In step 2 you recommend using new adhesive. What adhesive is recommended exactly?
See this youtube video from Lenovo on LCD tape, how to find what kind, how to remove it, and how to reapply it.
Robert -
Ok, 15 minutes to complete this is ridiculous. A seasoned person couldn't do this in 15 minutes, especially when removing and replacing adhesive, etc. That must be a typo.
