Lenovo Yoga Book X90F Motherboard Replacement
Выберете то, что вам нужно
  1. Lenovo Yoga Book X90F Motherboard Replacement, Bottom Screen/Keyboard: шаг 1, изображение 1 из 1
    • Turn off and power down the device before beginning this process. A heat gun or hair dryer will be suitable to heat the adhesive that holds down the screen. Apply heat to the entire surface area of the bottom screen.
    • New adhesive will be required when completing the steps in reverse order.
  2. Lenovo Yoga Book X90F Motherboard Replacement: шаг 2, изображение 1 из 2 Lenovo Yoga Book X90F Motherboard Replacement: шаг 2, изображение 2 из 2
    • Once the adhesive has been heated up, take the iFixIt suction cup and lift in a corner. The screen should be separating from the adhesive here.
    • While the screen is lifted, insert the ifixit opening pick to help pry off the screen.
    • The screen may crack easily as it is thin and fragile.
  3. Lenovo Yoga Book X90F Motherboard Replacement: шаг 3, изображение 1 из 1
    • While the screen has been lifted, insert the plastic opening picks. Heat the adhesive and follow with the screen removal tool to ensure that you are not prying it apart with excessive force.
  4. Lenovo Yoga Book X90F Motherboard Replacement: шаг 4, изображение 1 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 4, изображение 2 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 4, изображение 3 из 3
    • After the screen has been opened, disconnect the ribbon connecting the bottom screen to the motherboard by gently pulling the ribbon with tweezers.
    • If there are black coverings on the tabs as shown in the second image, carefully remove them using a pair of tweezers.
    • You can find more information on Zero Insertion Force (ZIF) connectors on this guide.
  5. Lenovo Yoga Book X90F Motherboard Replacement: шаг 5, изображение 1 из 1
    • Separate and remove the bottom screen from the device.
  6. Lenovo Yoga Book X90F Motherboard Replacement, Battery: шаг 6, изображение 1 из 3 Lenovo Yoga Book X90F Motherboard Replacement, Battery: шаг 6, изображение 2 из 3 Lenovo Yoga Book X90F Motherboard Replacement, Battery: шаг 6, изображение 3 из 3
    • Using a JIS #0 screwdriver, remove the single 8 mm screw.
    • Disconnect the battery cable from the motherboard.
  7. Lenovo Yoga Book X90F Motherboard Replacement: шаг 7, изображение 1 из 1
    • Use the opening pick to remove the two black strips on each side of the battery so the battery is cleared of any obstructions.
  8. Lenovo Yoga Book X90F Motherboard Replacement: шаг 8, изображение 1 из 2 Lenovo Yoga Book X90F Motherboard Replacement: шаг 8, изображение 2 из 2
    • The battery is glued down to the frame of the computer.
    • Wedge the opening pick underneath the battery and work your around the battery.
  9. Lenovo Yoga Book X90F Motherboard Replacement: шаг 9, изображение 1 из 1
    • Once the adhesive begins to unstick from the battery, remove the battery from the device.
  10. Lenovo Yoga Book X90F Motherboard Replacement, Motherboard: шаг 10, изображение 1 из 2 Lenovo Yoga Book X90F Motherboard Replacement, Motherboard: шаг 10, изображение 2 из 2
    • Above the battery on the bottom of the computer is the motherboard. On the left side of it, there is a strip of black tape covering a connection to the computer.
    • Remove the tape, and pull the connection off the motherboard.
  11. Lenovo Yoga Book X90F Motherboard Replacement: шаг 11, изображение 1 из 2 Lenovo Yoga Book X90F Motherboard Replacement: шаг 11, изображение 2 из 2
    • Disconnect the ribbon cable from the motherboard.
  12. Lenovo Yoga Book X90F Motherboard Replacement: шаг 12, изображение 1 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 12, изображение 2 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 12, изображение 3 из 3
    • Remove the two pieces of tape to reveal two ribbon cables.
    • Disconnect the two ribbon cables from the motherboard.
  13. Lenovo Yoga Book X90F Motherboard Replacement: шаг 13, изображение 1 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 13, изображение 2 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 13, изображение 3 из 3
    • Disconnect the two cables on the right hand side of the motherboard.
  14. Lenovo Yoga Book X90F Motherboard Replacement: шаг 14, изображение 1 из 2 Lenovo Yoga Book X90F Motherboard Replacement: шаг 14, изображение 2 из 2
    • On the left side of the motherboard, there is a silver metal plate with a screw holding the motherboard to the computer.
    • Using the JIS #00 screwdriver, remove the single 8 mm screw and the plate from over the motherboard.
  15. Lenovo Yoga Book X90F Motherboard Replacement: шаг 15, изображение 1 из 2 Lenovo Yoga Book X90F Motherboard Replacement: шаг 15, изображение 2 из 2
    • Underneath the plate are three wires.
    • Disconnect the three cables from the motherboard.
  16. Lenovo Yoga Book X90F Motherboard Replacement: шаг 16, изображение 1 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 16, изображение 2 из 3 Lenovo Yoga Book X90F Motherboard Replacement: шаг 16, изображение 3 из 3
    • Using the JIS #00 screwdriver, remove three 8 mm screws at the top of the motherboard.
  17. Lenovo Yoga Book X90F Motherboard Replacement: шаг 17, изображение 1 из 2 Lenovo Yoga Book X90F Motherboard Replacement: шаг 17, изображение 2 из 2
    • Using a pair of tweezers, pull the motherboard off the computer.
Заключение
Ryan James
Участник с: 09/28/21
157 Репутация
1 руководство автора
Команда
Clemson, Team 5-2, Hunter Fall 2021 Участник Clemson, Team 5-2, Hunter Fall 2021
CLEM-HUNTER-F21S5G2
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 7
За последние 30 дней: 28
За всё время: 805
