Выберете то, что вам нужно
Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
Remove the microSD card slot cover. Remove any microSD card (if inserted).
Using a Phillips head screwdriver, remove the three 0.75 mm screws.
Orient the device so the screen is facing you.
Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
Continue to detach the backplate from the frame by moving the spudger around the perimeter.
Locate the screws in the motherboard the wire cover assembly and the speakers.
Use the J000 screwdriver to remove the screws on the motherboard, the wire cover, and the two speakers.
Disconnect the wifi connector on the motherboard.
Use the spudger to lift the two speakers up from the small adhesive strip.
Place the spudger in the upper left corner of the motherboard and lift it to separate it from the adhesive strip under it.
Lift away the motherboard.
13 участников успешно повторили данное руководство.
Один комментарий
Dear @phanudej ,
I liked your post. I’d have a remark and a question. I made a mistake during the maintanance; with wich I killed a part of the MOBO. So dear users my advice if you want to connect the LCD connector remove the battery before… I had never this issue but now happened. (the device was switched off)
Could you please take a photo of the powerstage of the LCD (I think it should be that) So between the inductor (100; 10uH coil) and an capacity there is a component I do not know what is it (it smoked away) I assume it is a diode…?! They are in the white rectangle near the LCD connector
Thanks in advance
Best regards
