Выберете то, что вам нужно
Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
Remove the microSD card slot cover. Remove any microSD card (if inserted).
Using a Phillips head screwdriver, remove the three 0.75 mm screws.
Orient the device so the screen is facing you.
Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
Continue to detach the backplate from the frame by moving the spudger around the perimeter.
Remove the 3 screws from the auxiliary port cover.
Use the spudger to gently push the auxiliary module out of the way.
Remove the detachable plastic latch located in front of the hinge.
Use the pointed end of a spudger to push in the camera's locking mechanism.
Upon releasing the camera lock lift the camera out and locate the three screws.
Use a J000 Philips screwdriver to remove the three screws.
Remove the camera cover that seals the camera case.
Remove the camera from the shell.
2 человек успешно провели ремонт по этому руководству.
1Комментарий к руководству
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
