Выберете то, что вам нужно
Open the kickstand by pressing the release button in the center.
Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
Work along the edge and then up the sides, separating the clips with the plastic opening tool.
this step is not clear. Where are the clips ? The screen looks inset. How to insert the tool ?
3 участников успешно повторили данное руководство.
Один комментарий
Had put the SIM in the Memory card slot, instructions came in handy.
