Lenovo Yoga Tab 3 8 Wifi Module Replacement
Выберете то, что вам нужно
  1. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: шаг 1, изображение 1 из 3 Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: шаг 1, изображение 2 из 3 Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: шаг 1, изображение 3 из 3
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 2, изображение 1 из 1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 3, изображение 1 из 3 Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 3, изображение 2 из 3 Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 3, изображение 3 из 3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Wifi Module: шаг 4, изображение 1 из 1
    • Locate the WiFi module connection on the motherboard by following the grey wire along the bottom. Use a spudger to gently pry it off.
  5. Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 5, изображение 1 из 2 Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 5, изображение 2 из 2
    • Locate the copper foil holding down the WiFi module near where the grey wire connects. Use tweezers to carefully lift up and separate the copper foil.
  6. Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 6, изображение 1 из 1
    • Remove the three 2mm screws holding the wifi module to the device using a PH00 screwdriver.
  7. Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 7, изображение 1 из 2 Lenovo Yoga Tab 3 8 Wifi Module Replacement: шаг 7, изображение 2 из 2
    • Remove the grey wire from the channel holding it by gently lifting it up with your fingers.
    • Lift the wifi module out of the device with your fingers.
Заключение
Nicklaus Krems
Участник с: 09/25/17
1 049 Репутация
Автор 8 руководств
Команда
USF Tampa, Team S16-G2, Eyestone Fall 2017 Участник USF Tampa, Team S16-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S16G2
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 1,736
