Введение
Before you proceed with this guide, you should know how to remove the back cover.
Выберете то, что вам нужно
Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
Remove the headphone jack cover with tweezers by grabbing it and pulling directly up and away from the device.
Disconnect the headphone jack from the motherboard by placing the spudger in between the connections and motherboard and pushing up towards you.
Pull the wire towards the headphone jack to disconnect it.
Еще один человек закончил это руководство.
