Выберете то, что вам нужно
Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
Use the tweezers to lift the black tape from the corner of the printed circuit board.
Remove the wire from the PCB by pulling it towards the edge of the headphone jack using tweezers.
