Введение
In this guide, there will be a step by step process on how to remove a broken display screen for a Lenovo Yoga Tablet 2 830-F. Each step is done in order to ensure all pieces are taken off correctly without breaking.
Запчасти
Детали не указаны.
Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
Remove the six screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
Remove the three screws on the back of the secondary board with the Phillips Screwdriver #00 bit.
Remove the ribbon cables connecting the boards to the other electrical components
Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
Remove the three 2mm screws on the back of the right speaker module.
Use the opening tool to pry the battery compartment off the right hand side of the back.
3 участников успешно повторили данное руководство.
