Инструменты
Запчасти
Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
Remove the 2mm screw on the back fo the device with a Phillips #00 bit.
Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
Remove the ribbon cables connecting the boards to the other electrical components
Remove ZIF connectors connecting the boards to the electrical components.
Почти готово!
Заключение
