Введение
This guide will demonstrate the step by step process on how to replace the motherboard in your Lenovo Z70-80.
Выберете то, что вам нужно
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Remove the two Phillips #0 screws from the bottom panel.
Slide the panel down slightly, and then lift to pull it off.
Remove the single 3mm Phillips #0 screw from the optical drive.
Pull the optical drive out of the side.
Remove the three 6mm Phillips #0 screws from the fan.
Disconnect the fan from the motherboard by pulling up on the plug.
Remove all the 17 7mm Phillips #0 screws.
A sticker covers this screw. Remove this sticker to remove the screw.
Remove the back cover.
Pry the edges of the keyboard upwards using a spudger.
Remove the five 3mm Phillips #0 screws.
Remove all the ribbon cables and connectors from the front and back of the laptop.
Remove the 3mm screw and carefully pull out the cables from the hooks holding them in place.
Use a spudger at the edges of the laptop cover to carefully pry upwards, removing the cover.
Unplug the two black cables from the motherboard.
Remove the three 3mm screws from the motherboard.
Remove the motherboard.
3 участников успешно повторили данное руководство.
