Введение
Your axe isn't sounding right or just isn’t working but you don't want to spend a lot to fix it? This will let you change out your pickups in no time, without damaging your wallet in the process. Have a new set of pickups ready and you can jump right in. This guide will walk you through the process of changing the pickups on your Les Paul guitar.
Выберете то, что вам нужно
Loosen the guitar strings using a string winder.
Using a coin, carefully begin unscrewing and removing the tailpiece.
Remove the tailpiece by completely unscrewing it from the metal inserts and then gently lifting the assembly out of the body and set off to the side.
Use the Phillips #0 screwdriver to remove the eight screws keeping the pickups in place.
Note which color wire is coming out of each pickup.
Gently flip over your guitar and put it on a soft towel or other soft material. Take off the control cavity cover.
Desolder the wires of the pickup from the terminal that is touching the back of the potentiometer, or pot.
Flip over your guitar again. Thread the wire of the new pickup through the body to the control cavity and screw in the pickup using the Phillips #0 screwdriver.
Solder the new ground wires to the back of the volume pots or to the terminal touching the back of the pot.
Identify your hot wires and volume pots and solder the hot wire to the center terminal of the wires corresponding pot.
Raise and lower the pickups as desired using the two screws on the sides of the pickup rings.
Plug in your beloved guitar and rock out with your fresh pickups
2 участников успешно повторили данное руководство.
