Введение
Is your Levoit LV-H132 not turning on because the cable is damaged? Does the cord create sparks when plugged in or does it smell burnt? If the power cord doesn’t allow power transmission, then the air purifier will certainly not power up. To fix that, we have to replace it. So, use this guide to fix your damaged cord.
Выберете то, что вам нужно
Use a heat gun to heat up the heat-shrink tubing wraps.
Disconnect the damaged cable from the wires that are connected to the motherboard.
