Введение
If the control panel on your Levoit LV-H132 device is not working when it's connected to the power outlet, then it is time to replace the motherboard. Is the device overheating, producing strange noises, or smell burnt? Then the motherboard must have short circuited. Other causes could be that it has gone bad or gone old.
Выберете то, что вам нужно
Remove the two 5 mm screws that hold the motherboard vertically with a Phillips #1 screwdriver.
Remove four 5 mm screws from the motherboard cover with a Phillips #1 screwdriver.
Remove two 6 mm screws that hold the motherboard in place with a Phillips #1 screwdriver.
2 участников успешно повторили данное руководство.
