Введение
Ink cartridges allow the printer to print using the ink in the cartridges. The colors included are black, yellow, blue and pink.
Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
Once your ink cartridges are in place, your printer should now print high-quality documents.
2 участников успешно повторили данное руководство.
Один комментарий
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
