Lexmark T650 Fuser Roller Replacement
Выберете то, что вам нужно
    • A damaged pressure roller leads to paper jams.
    • A damaged non-stick coating on the heated roller causes dark marks and double images. Toner that sticks to the non stick coating on the heated roller makes an after-image or marks 94mm (3.7 inches) below the original dark print.
  1. Lexmark T650 Fuser Roller Replacement, Remove front cover: шаг 2, изображение 1 из 1
    • Remove these two 6mm Philips #2 screws then remove the front cover
  2. Lexmark T650 Fuser Roller Replacement, Remove top cover: шаг 3, изображение 1 из 2 Lexmark T650 Fuser Roller Replacement, Remove top cover: шаг 3, изображение 2 из 2
    • Remove these two 6mm #2 screws from the two ends of the heating element and carefully withdraw the glass heating element.
    • The glass heating element is shown in the second picture.
    • Remove these two 6mm #2 screws attaching the top cover.
    • Remove this screw attaching the red power cable.
    • Unplug the pair of yellow wires and unhook them from the hooks tucking them in place.
    • The top cover can now be removed.
  3. Lexmark T650 Fuser Roller Replacement, Release the springs: шаг 4, изображение 1 из 2 Lexmark T650 Fuser Roller Replacement, Release the springs: шаг 4, изображение 2 из 2
    • Insert a wedge under each of the two spring support arms to lift the two springs.
    • The wedges should remain in place while the fuser unit is being stored. Otherwise the pressure from top roller will make a permanent indentation in the soft pressure roller.
    • The second picture shows a suitable wedge. This example was made from a toothbrush handle.
  4. Lexmark T650 Fuser Roller Replacement, Remove paper guide: шаг 5, изображение 1 из 2 Lexmark T650 Fuser Roller Replacement, Remove paper guide: шаг 5, изображение 2 из 2
    • gently bend this paper guide to remove it.
  5. Lexmark T650 Fuser Roller Replacement, Remove top roller: шаг 6, изображение 1 из 3 Lexmark T650 Fuser Roller Replacement, Remove top roller: шаг 6, изображение 2 из 3 Lexmark T650 Fuser Roller Replacement, Remove top roller: шаг 6, изображение 3 из 3
    • Use circlip pliers to remove the circlip attaching the cogwheel to the top roller.
    • Slide this metal catch upwards to release the bearing from its holder. Remove the bearing.
    • The top roller can now be removed.
    • The red pressure roller is now visible with its bearings resting in the holder at each end.
  6. Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: шаг 7, изображение 1 из 2 Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: шаг 7, изображение 2 из 2
    • The pressure roller can now be lifted out.
Заключение
3 человек успешно провели ремонт по этому руководству.
David42
Участник с: 02/11/18
1 468 Репутация
Автор 7 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 37
За всё время: 1,688
