Введение
Перейти к шагу 1 ↓This guide will help you change your engine air filter quickly and easily. Changing the engine air filter in your Lexus IS350/250 is essential for maintaining optimal engine performance and fuel efficiency. Before starting, ensure your car is parked on a flat surface, the engine is cool, and you have the correct replacement filter. Be cautious of sharp edges under the hood and make sure to secure the hood properly to avoid it falling.
Additional Information:
- Caution: Make sure the engine is cool before starting this procedure to avoid burns.
Выберете то, что Вам нужно
Запчасти
Pull the hood latch located under the dashboard on the driver’s side to release the hood.
Raise the car's hood until the hood struts engage and hold it in the open position.
Locate the engine air filter box, positioned in front and to the side of the engine.
Squeeze the three clips securing the air filter box cover to release them from the cover.
Place the new air filter inside the air filter box.
Close the engine air filter box lid and secure the clips.
Close the hood of the car by carefully lowering it and ensuring it is latched properly.
Start your car and ensure it runs smoothly. Check for any unusual noises or issues.
You have successfully changed your engine air filter for your Lexus IS350/250!
3 человек успешно провели ремонт по этому руководству.
