Lezyne CNC Dirt Floor Drive Gauge Replacement
Выберете то, что вам нужно
  1. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: шаг 1, изображение 1 из 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: шаг 1, изображение 2 из 2
    • Using a flat head screwdriver, pry up an edge of the gauge cover.
    • Remove the gauge cover.
  2. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: шаг 2, изображение 1 из 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: шаг 2, изображение 2 из 2
    • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
    • Pry up a corner of the gauge face plate.
    • Use pliers to pull off the gauge face plate.
    • Be careful when prying off the face plate, as the edges are sharp.
    • Use pliers to remove the internal gauge mechanics.
  3. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: шаг 3, изображение 1 из 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: шаг 3, изображение 2 из 2
    • Using pliers, grip the exposed brass piece and unthread the gauge by rotating the gauge counter-clockwise.
    • Pull the gauge out of its housing.
  4. Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: шаг 4, изображение 1 из 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: шаг 4, изображение 2 из 2
    • Remove the O-ring that is at the bottom of the threaded hole that the gauge threaded into.
    • Place a new O-ring into the hole.
  5. Lezyne CNC Dirt Floor Drive Gauge Replacement, Applying Threadlocker: шаг 5, изображение 1 из 1
    • Apply medium-strength Loctite (green, 290) to the threads of the new gauge.
  6. Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: шаг 6, изображение 1 из 3 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: шаг 6, изображение 2 из 3 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: шаг 6, изображение 3 из 3
    • Thread the new gauge into the floor pump by turning it clockwise in its housing.
    • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
    • Allow at least 30 minutes for the thread locker to set.
    • Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
Финишная черта
Еще один человек закончил это руководство.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
7 Комментариев
i use both gold and silver bracelets because for me, they are both great bracelets to wear;; <a href="https://www.chinamaijin.com/">cnc machining</a>
saif 77 - Ответить
Its good  as your other  content  : D,  appreciate it for posting . <a href="https://www.chinamaijin.com/">cnc machining parts</a>
saif 77 - Ответить
I feel nice about it and love learning more about this topic. <a href="https://certifiedbourbon.com/product/blu...">blue label for sale</a> I will come to your site to find out more and tell my acquaintances about you.
Biplob Chandra Singha - Ответить
Nice information and good tips for SEO off-page optimization. I have got good tips to improve SEO off-page Optimization. Thanks for sharing! <a href="https://certifiedbourbon.com/product/pap...>pappy van winkle online</a> please keep it up Maintains!
legalweed suppliers - Ответить
I was checking continuously this list and I’m impressed! Extremely useful info especially this blog commenting sites list. <a href="https://mushroomlux.com/product/dmt-cart...>purecybin dmt</a> Thank you and best of luck.
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 5,469
