Введение
This guide is for first time builders or people that bought prebuilt computers in a Lian Li PC-011 case. This guide will walk you through how to install or replace a 3.5 hard drive in the case. It is not a very difficult task and it should only take you 30 minutes to complete.
Выберете то, что вам нужно
Power off the system using the button on the back of the computer.
Remove the power cord from the computer.
Remove two thumb screws from the back of the case.
Slide the top panel backwards.
Push together the bottom and top tabs and pull the hard drive tray out of the case.
7 человек успешно провели ремонт по этому руководству.
