Введение
This guide will show you the steps to replace the battery of the LifeTrak C410. Replacement battery can be found here.
Выберете то, что вам нужно
Grasp the body of the watch between your thumb and your index finger.
Slide the band through its clasp.
Remove the four 5.24 mm screws using a Phillips #0 screwdriver.
Remove the back panel.
Pull on the white tab to release the battery.
While holding the watch upside down, pull the battery out.
2 участников успешно повторили данное руководство.
