Введение
This is a guide will show you how to fix a detached leg from a 4-foot adjustable folding table from Lifetime. Whether it's from excessive weight, gradual deterioration, or accidental impacts, the chances of table leg damage increases with use. This tutorial is designed to help people understand what to do if the table legs become detached.
Выберете то, что вам нужно
Use the 6 mm Flathead screwdriver to remove the four aluminum slotted screws located on the edges of the table.
Use a 5/32" Allen Wrench or 19 mm wrench to remove the two stainless 8-18 steel hex screws from the braces of the table.
Clean any glue or adhesive from the braces and hinges before putting it into place.
Align the screw holes of the braces with the new leg by inserting it into the frame.
Place the two stainless steel hex screws inside of the screw holes located on the leg, and secure each screw with your Allen key or wrench.
Screw the four slotted screws back into the frame using a 6 mm flathead screwdriver. Ensure that the entire side where the new leg is being inserted is securely connected to the table once again.
