Введение
We will be replacing the 3.7V/900MA re-chargeable Lithium Battery in the camcorder.
The first step will require you to take off the cover where the battery will be located under
Pull this strap upward and the battery will pop right out
You will then be able to replace the battery as needed
Еще один человек закончил это руководство.
