Linksys E1200 Router Power Adapter Replacement
Выберете то, что вам нужно
  1. Linksys E1200 Router Power Adapter Replacement, Power Adapter: шаг 1, изображение 1 из 1
    • Take note of the wire labeling. Each wire has either a Stripe or Text. When lining up the wires after cutting, it is critical that you keep Stripe with Stripe, and Text with Text. Failure to do so will result in damage to the device.
  2. Linksys E1200 Router Power Adapter Replacement: шаг 2, изображение 1 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 2, изображение 2 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 2, изображение 3 из 3
    • Begin by cutting the wire.
    • Strip the wire.
    • Seperate the two halves of each wire, and split the two with a utility knife. Don't go too far! You will need the extra space to overlay HeatShrink before the soldering is down.
  3. Linksys E1200 Router Power Adapter Replacement: шаг 3, изображение 1 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 3, изображение 2 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 3, изображение 3 из 3
    • Twist the individual strands together to make a single pigtail.
    • Overlay with the corresponding wire (Step 1), and twist together, but not before sliding on the HeatShrink.
  4. Linksys E1200 Router Power Adapter Replacement: шаг 4, изображение 1 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 4, изображение 2 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 4, изображение 3 из 3
    • Pull the wire seperation back far enough on at least one side to permit Heat-Shrink to slip over the wire insulation.
    • Now the soldering. Place the pre-heated iron on the wires on a heat-resistant, flame proof surface. Make sure that the Heat-Shrink is nowhere near the soldering iron.
    • Let it heat for a few sconds (copper is an excellent conductor of heat), then touch the end of the solder to the wire. If fully heated, it should flow easily into the joint.
  5. Linksys E1200 Router Power Adapter Replacement: шаг 5, изображение 1 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 5, изображение 2 из 3 Linksys E1200 Router Power Adapter Replacement: шаг 5, изображение 3 из 3
    • To protect the solder job, you will need to slide the shrink wrap over the patch, then heat it so that it grips the wire securely. You can use a heat gun or the flat side of a soldering iron. Be careful to not let it burn!
    • Repeat for the other wire. Repeat for the overall sheath.
Заключение
Tahisha Hicks
Участник с: 02/24/14
409 Репутация
Автор 4 руководств
Команда
Michigan Tech, Team 5-4, Lauer Spring 2014 Участник Michigan Tech, Team 5-4, Lauer Spring 2014
MTU-LAUER-S14S5G4
3 членов
Автор 7 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 2,829
