Введение
For optimal performance, the middle antenna needs to be pointed straight up and the side antennas should be angled outwards at +/- 30 degrees.
If the antennas are not staying in place, it could affect the performance of the router, and you need to be replace them.
Выберете то, что вам нужно
Remove the antennas by unscrewing them from the base.
Flip over the device and locate the four rubber feet on the bottom.
Remove the rubber feet with tweezers
Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
Use a blue plastic opening tool to remove the top cover.
Move the blue plastic opening tool gently underneath the top cover from side to side.
Gently lift the motherboard and remove it from the case
Put the motherboard over a (preferably white) surface.
Detach the wires from the motherboard.
Flip the motherboard and repeat the process.
Locate the four solder points on each port and melt them using a soldering iron.
Remove each port using a nylon spudger
4 участников успешно повторили данное руководство.
