Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Start by removing the two black rubber stoppers that act as the cushions to the legs of the device. The stoppers are located on the bottom towards the front of the device.
Once removed two small screws will be visible. With a small screwdriver unscrew the screws.
Remove the blue front panel from the rest of the device. You can now see the main board.
Now slide the bottom panel forward and remove it so the main board is attached to the bottom panel.
From here, remove the wires and nuts connected to the back panel of the casing by pulling the nuts through the holes in the casing.
Once the bottom panel is removed unscrew the screws from the main board to the bottom panel so the main board is independent of the bottom panel.
From here, all of the pieces of the casing are removed and the main board is independent of the entire casing.
Еще один человек закончил это руководство.
