Linksys e1200 Wireless Router Ethernet Port Replacement
Выберете то, что вам нужно
  1. Linksys e1200 Wireless Router Ethernet Port Replacement, Ethernet Port: шаг 1, изображение 1 из 3 Linksys e1200 Wireless Router Ethernet Port Replacement, Ethernet Port: шаг 1, изображение 2 из 3 Linksys e1200 Wireless Router Ethernet Port Replacement, Ethernet Port: шаг 1, изображение 3 из 3
    • The PC board is loosely attached to the plastic base. Note the micro-soldered terminals on the Ethernet ports. These are very small and require significant expertise to desolder and replace.
  2. Linksys e1200 Wireless Router Ethernet Port Replacement: шаг 2, изображение 1 из 1
    • Do to modern manufacturing, you will need to cover the area in solder flux; it is messy, so be careful.
    • Prep your desoldering braid by pulling it into a shape that will allow it to contact the solder on the baord itself.
    • Touch the soldering iron to the top of the contact after it has heated sufficiently; the flux will melt, as will the solder, and both should flow into the desoldering braid.
  3. Linksys e1200 Wireless Router Ethernet Port Replacement: шаг 3, изображение 1 из 2 Linksys e1200 Wireless Router Ethernet Port Replacement: шаг 3, изображение 2 из 2
    • After removing all of the solder from each terminal, you may try pushing out the ethernet port. If it won't go, you need to remove more solder.
    • If neccessary, you will need to make a custom tool to touch all of the contacts at once. This one is made of bent copper wire and can replace the tip on a pencil-style soldering iron.
    • Once the ethernet port is removed, you may replace it (or anything else you had to remove), and solder it to the circuit board.
    • You can find many fine soldering guides online, here is a reccommended one: http://www.wikihow.com/Solder-%28Electro... Remember to add flux to the joint prior to soldering.
Заключение
Tahisha Hicks
Участник с: 02/24/14
409 Репутация
Автор 4 руководств
Команда
Michigan Tech, Team 5-4, Lauer Spring 2014 Участник Michigan Tech, Team 5-4, Lauer Spring 2014
MTU-LAUER-S14S5G4
3 членов
Автор 7 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 3,063
