Введение
Is your disco ball not sending out groovy beams of light anymore? The most common problem is the light bulb is burnt out. This guide will teach you how to replace that light bulb, so you can get back to partying!
Выберете то, что вам нужно
Turn the device over, so that the base is on top.
Compress the tab by pushing towards the center of the device with a spudger.
While compressing the tab, peel the base away from the rotating head.
If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
5 участников успешно повторили данное руководство.
4 Комментариев
Great! Wasn't sure how to remove the base. Thank you!
Saved me a headache. Couldn't figure out how to remove base. Thanks!
Thank you so much! I was afraid of breaking the globe. That really helped because I couldn’t figure out how to disconnect the base.
