Введение
Will your groovy disco ball not turn on? This guide will teach you to remove and replace the switch so you can get back to your partying.
Выберете то, что вам нужно
Use a Phillips head screwdriver to unscrew the single screw.
Remove the panel that conceals the switch.
Hold on to the red disc with needle nosed pliers, and use the Phillips head screwdriver to remove the disc by pushing down.
Почти готово!
Заключение
