Введение
Use this guide to replace the clutch assembly in a Little Beaver Augers MDL5HD 2017.
The auger bit is removed in this guide. While not necessary, removing it will make the repair easier.
Выберете то, что вам нужно
Pull the spark plug connector straight off of the spark plug.
Use a 5/16 inch socket to remove the two nuts securing the clutch bracket clamp.
Use a 5/32 inch hex wrench to loosen the two set screws on the clutch drum.
Use a flathead screwdriver or small pry bar to pry the clutch drum off of the flexible shaft.
Slide the clutch drum off of the flexible shaft and remove it.
Use a long-handle 5/32 inch hex wrench to loosen the two set screws on the clutch rotor assembly.
2 участников успешно повторили данное руководство.
